I'm facing this strange situation related to setting of my beosystem 3.I have it setup with Beolab 7-1 (center), Beolab 2, beoalb 8000 as from speakers and Beolab 6000 as rear.Recently I noticed that 6000 sound distorted. After taking a close look 6000 were due for re-foaming.In short I have disconnected them from the system for about a week. After fixing woofers I connected lab 6000 to beosystem but cant get them to work!Beosystem detects them in speaker types menu, however in speaker roles they show as NONE, Then I assign them role of rear speakers and try to store I get no confirmation. So when I come back to this menu they are shown as NONE.In Adjustment Menu I have only these and can only change to SPEAKER 2 or 1 DEFAULT VIDEO SPEAKER 3 DEFAULT AUDIO SPEAKER 3Please help!
Below all SOUND settings of Beoystem 3
TV SETUP/OPTIONS/SOUND
SOUND SETUP
* ADJUSTMENT DEFAULT VIDEO SPEAKER 3 (Used to be 5) DEFAULT AUDIO SPEAKER 3 (Used to be 5)
* SPEAKER TYPES CENTRE 1 - Beolab 7-1
SPEAKERS
Beolab 2 Beolab 2 (grayed out/disabled) Beolab 8000 NONE NONE Beolab 8000 NONE NONE Beloab 6000 NONE NONE Beolab 6000
*TV SPEAKER ROLES SUBWOOFER SUBWOOFER LEFT FRONT NONE (grayed out/disabled) NONE (grayed out/disabled) RIGHT FRONT NONE (grayed out/disabled) NONE (grayed out/disabled) NONE (produce sound when selected) NONE (grayed out/disabled) NONE (produce sound when selected) NONE (grayed out/disabled)
*TV SPEAKER DISTANCE CENTRE LEFT FRONT RIGHT FRONT SUBWOOFER*TV SPEAKRE LEVEL LEFT FRONT RIGHT FRONT
*SOUND SYSTEM
INPUT FORMAT DOLBY DIGITAL 5.1
OUTPUT FORMAT DOLBY DIGITAL SPEAKER 3
BeoSystem 3BeoSound 9000BeoLab 8000/6000/4000/3500/BL2PlayMakerBeoCenter 9300BeoGram 5500BeoCom1/1600 + BeoTalk 1200BeoCord vx5500
David:* TV SPEAKER ROLES SUBWOOFER SUBWOOFER LEFT FRONT NONE (grayed out/disabled) NONE (grayed out/disabled) RIGHT FRONT NONE (grayed out/disabled) NONE (grayed out/disabled) NONE (produce sound when selected) NONE (grayed out/disabled) NONE (produce sound when selected) NONE (grayed out/disabled)
I do press GO to store.Apparently I have to select LEFT/RIGHT SURROUND SPEAKER and NOT LEFT/RIGHT REAR SPEAKERIt helps to read manual sometimes :)
