Recommendations for new projector
This post has 8 Replies | 0 Followers
kai
Posts 362
kai Posted: Tue, Jun 26 2018 6:37 PM
Can any one recommend a replacement for jvc projector, we thought it was just a lamp but it’s the power supply that has gone, sadly it can be fixed, what is the best replacement it’s and older system bvis 4-65 with beosystem 3
Thanks for any help
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Jun 26 2018 9:40 PM
I use a Sony VPL-HW55 with BeoSystem 4 - used it with BeoSystem 3 before that and it is one of the best 1080p projectors out there. Around 1.000€ second hand.
Ralf
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jun 27 2018 9:04 PM
kallasr:
Ralf
I was interested in the Sony Projectors but couldn't find them in the BeoSystem PUC. Were you able to get a PUC file for yours?
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jun 27 2018 9:06 PM
I meant to say that I couldn't find the Sony projectors in the BeoSystem 4 PUC.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jun 27 2018 9:40 PM
Not using PUC on the projector. IR cable would be too long. Wireless HDMI for connection.
Sorry. But Homecinema Room is not used daily. So fine for us...
Forgot to mention I never looked for Sony projectors in the puc database.
Ralf
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jun 27 2018 10:03 PM
One work-around is to use a Lintronic box to send out the IR codes when the CINEMA ON/OFF triggers are received. The box can send out the IR signal across the room wirelessly. Still, I had higher hopes that B&O would populate the PUC database better than it has. The choices for screens and projectors are pretty small.
kai
Posts 362
kai replied on Thu, Jun 28 2018 3:54 PM
Thanks for the replies, looks to me the bat choice would be to replace the jvc with another one, 10 years it pretty good service, and the new one has the same dimensions, unless someone has a better suggestion?
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jun 28 2018 8:03 PM
I think Kallasr has a good recommendation with the Sony projector. The specs of the recent Sony projectors look much better than projectors from 10 years ago. They even support 3D for those of us who have a legacy 3D movie collection. Is your concern about the PUC control?
Lintronic has good instructions on how to use the CINEMA data control to trigger projectors, screens, etc. You do have to cross-over pins of the RS232 cables. I did this easily with (2) RS232 breadboards.
kai
Posts 362
kai replied on Fri, Jun 29 2018 7:26 AM
Hi beojeff, thanks for the reply, I know when it was set up they wired up a 12v trigger box. It’s always work. Once new projector is in place I will see if it’s still working, and post some pics, thanks for the advise
Page 1 of 1 (9 items) | RSS
