hi,
The B&O App is recognizing the A2 and is asking if I want to set it up. But afterwards it’s not shown in the product list.
is it supposed to work with this app or only with the Beoplay?
stampfki:hi, The B&O App is recognizing the A2 and is asking if I want to set it up. But afterwards it’s not shown in the product list. is it supposed to work with this app or only with the Beoplay?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Yes, this should work with the B&O App as said by iCloud Support. I have also tested myself it is working very fine. It will also work with Beoplay. I don't know why in your case it is not working. You can also ask them, they will surely resolve your issue.
rogger007: Yes, this should work with the B&O App as said by iCloud Support. I have also tested myself it is working very fine. It will also work with Beoplay. I don't know why in your case it is not working. You can also ask them, they will surely resolve your issue.
I don’t knaow which experience you are referring to - nor why you post a link to an Apple support site.
The answer that Hiort gave is correct!
The A2 is a bluetooth speaker - enjoy it as such....sending from any bluetooth enabled source device.
@MM and all : the post is a scam, it's not a link to Apple. MODERATOR PLEASE DELETE (I've tried the function "report abuse" but it's not working).
diisign.com
