BeoNut since '75
https://bogo.custhelp.com/app/answers/answer_view/a_id/13309/loc/en_GB
According to this there is an IR version of the CORE - so just be careful which one you choose
@ elephant
NOTE! New Mark II of BeoSound Core: BeoSound Core with IR Type No. 3051.BeoSound Core version without IR type no. 2797. (should now be sold out in DK).
@ chucky
Thanks for your reply.
The question is if it works ?
Peter Pan:@ chucky Thanks for your reply. The question is if it works ?
chucky:Yes on version 3051 it does. This series contains a hardware upgrade of part 1293042
Hallo chucky
