Beocenter 2200 tonearm
IanB
Posts 1
IanB Posted: Tue, Apr 10 2012 10:32 AM
I recently picked up a Beocentre 2200 - without the MMC 5 Cartridge- if I can't pick a replacment up (as they do seem rare) - is it possible to replace the tonearm with something easier to find - or is there another cartridge I can use - I had heard that there is a Shure type that can be fitted ?
Scott
Kirkcaldy,fife
Posts 2
Scott replied on Tue, Jul 17 2018 8:48 PM
I have recently picked up a 2200 turntable, and I too am looking fot a compatible cartridge. I'm a complete novice to b&o and these furum things. 😁 I also squired a 2000 amp/tuner and wondered it there are connectors that I can buy, that would allow me to use my existing speakers with the amp/tuner? As the connection on the back are different. Any info would be greatly appreciated.
Scott
Kirkcaldy,fife
Posts 2
Scott replied on Tue, Jul 17 2018 8:52 PM
I recently picked up a 2200 turntable. And it also needs a cartridge. Which carts are compatible with this turntable? I also squired a 2000 amp/tuner. And wondered if you can buy connectors that would enable me to use existing speakers. As the connection,s on the back are different. I'm new to b&o and these forum thingy,s. So any info would be greatly appreciated.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jul 17 2018 10:41 PM
If it’s a Beogram 2200 (that I also own) you can use a MMC 20E .
That is what the Beogram was supplied with when it was new.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jul 18 2018 6:08 AM
According to the thread title this is a Beocenter 2200, which uses the MMC1-5 range of cartridges.
Replacing the tonearm would spoil the looks and it would definitely not be an easy task.
But why? - MMC cartridges are plentyful and worn ones can be rebuilt.
The speaker connections on your Beomaster 2000 is 2-pin DIN.
That's actually the only industrial standard for home-stereo speaker connections in the world. Everything else is non-standard.
Plugs can be found on Ebay etc. both as screw-mount and solder types. The latter is usually the best (if you can solder).
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Jul 19 2018 9:14 PM
Scott:
You need these for the speakers:
https://www.ebay.co.uk/bhp/din-speaker-plug
Page 1 of 1 (6 items) | RSS
