Beocenter 2 and Beosound 5/Beomaster 5 in same room
frog
Camberley UK
Posts 624
frog Posted: Fri, Jul 27 2018 7:22 PM
Tearing my hair out on this one, but does anyone know how to connect these in a mainroom (there is a beosystem 3 which connects to the speakers). I can't find any combo which would allow RADIO from the BS2, and N.MUSIC/N.RADIO from the beosound 5/Beomaster 5.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Jul 27 2018 9:24 PM
this should work if the BeoMaster 5 is set to 'No Audio Master'. The Audio Master will then be the BeoCenter, the BeoMaster 5 / Beosound 5 combo will be then be only an additional Audio sorce which needs only be connected via Masterlink to deliver the selected audio.
Ralph-Marcus
frog
Camberley UK
Posts 624
frog replied on Sat, Jul 28 2018 1:25 PM
You know, I’ve tried that. Still no joy with the functions working correctly. It’s a real puzzle!
beojeff
USA
Posts 2,012
beojeff replied on Sat, Jul 28 2018 7:49 PM
I've had this combination before and I know it works. Perhaps you need to do a power cycle of all of your ML products.
frog
Camberley UK
Posts 624
frog replied on Sat, Jul 28 2018 10:11 PM
I wish it were. What are the options settings on your BS3, BC2?
frog
Camberley UK
Posts 624
frog replied on Sun, Jul 29 2018 7:14 PM
To clarify the effect, I can choose N.RADIO from the remote, the Beocentre 2 will display N.Radio on its display, the beosystem 3 will power up - but nothing comes out....
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Jul 30 2018 10:21 AM
i don't know for sure but setting the BeoMaster5 / BeoSystem 5 to  'A.OPT 0' should give the correct function
Right now the BC2 gets the IR command from the TV and the BM5 direct via its own IR receiver as it seems.
Ralph-Marcus
frog
Camberley UK
Posts 624
frog replied on Mon, Jul 30 2018 2:36 PM
That helped! Thanks. Now N.Radio works fine, but strangely, N.Music can’t be selected after N.Radio!
Page 1 of 1 (8 items) | RSS
