Hi all,
I recently bought a pair of H9i and really got amazed from the sound and build quality.
However, I noticed that while using them over Bluetooth they are draining my iPhone X's battery pretty quickly (about 20% in 1 and a half hour of music).
While my phone is connected to the cars multimedia system with bluetooth I don't see any extra-ordinary battery drainage.
Anyone experiences the same issue or has some tips?
I have an iphone x and H8.
Personally I don't notice any difference in battery when using BT or simply nothing. But I do feel the battery on the X is much worse than the 6 I had prior.
What does use lots of battery (at least for me) is when the screen is on, more screen on usage, more drain. For me if I really use screen time, I get about 1 day max. Lots of screen standby, about two days.
I’m still on 11.4.1.
Actually today I noticed that while using Waze for 1 and a half hour (screen was on) it consumed 40 percent of my battery, so probably it’s not related to the H9i. Not sure what happened but this started only recently ;(
