I've been looking around with no luck and thought this would be a good place to ask - I got my hands on one and it just needs it's geometry adjusted down a bit but I can't find anything about a service menu to do that on.
Does anyone know how to go about geometry adjustment on a MX3000? Thanks.
There is no service menu with this tv,all the adjustments are via preset resistors mounted along the rear edge of the pcb.I think there is a control for vertical position,but as these sets tended to suffer from capacitor(and other!) issues,you may have another problem?
The full service manual is available on site,but you will need to upgrade your membership for access to it.
Nick
