IR eye with Beosound Essence Mkll
This post has 4 Replies | 0 Followers
Teletom
Posts 27
Teletom Posted: Tue, Aug 28 2018 10:29 AM
Hi all,
Last week I bought an IR eye set for my BS Essence ll (BL9 combination). It works very nice, except for the following:
When I change sources (Tunein, Spotify or Music) I always hear a plop. However when using the B&O-app there is no plop at all.
Has anyone had the same experience? Your help is very much appreciated.
Johan
Aussie Michael
Melbourne, AU
Posts 3,730
Correct
Just like when you touch an a9, a6 etc (physically), it makes that noise to alert you you are changing sources
I also have an IR eye with BSE2
However when you don't physically touch it (app) it doesn't make it.
Millemissen
Flensborg, Denmark
Posts 14,680
You can turn off these ‘notification sounds’ in the settings of the product.
Teletom
Posts 27
Teletom replied on Tue, Aug 28 2018 12:18 PM
Thanks for your answer.
I have those plops (also) when using the Beo4 remote.
I do not have this plops when I change tracks within the same source.
Teletom
Posts 27
Teletom replied on Tue, Aug 28 2018 12:27 PM
Thanks MM for your advice!
That solved the problem.
Page 1 of 1 (5 items) | RSS
