How to open up a BEOLAB 4000?
UffeT
Posts 13
UffeT Posted: Sun, Sep 2 2018 7:56 AM
I have a problem. Owns two Beolab 4000, MK II, speakers and I need to change the amplifier board in one of them. I can remove the black speaker grille but after that I dont know how to proceed. Tried to find info on the Web but did not find any  useful information... What is the next step to be able to open the speakers?
Best Regards
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw replied on Sun, Sep 2 2018 8:42 AM
Hi
Having removed the grill, remove the 2 torx screws you can see which allows you to remove the metal shaped profile. This will reveal about a dozen more torx screws. Remove them, and you'll be in!
Cheers
Nigel
UffeT
Posts 13
UffeT replied on Mon, Sep 17 2018 8:45 PM
Hi again..
I´m sorry but I don´t  manage to remove the metal shaped profile. Seems impossible.
Dont know how much force to apply?
Any more tips or tricks?
//Ulf
UffeT
Posts 13
UffeT replied on Mon, Sep 17 2018 8:51 PM
Something is perhaps not correct.
I have 3x TX10 holding the profile?
Can not remove the profile after removing these 3 screws.. What to do?
marexy
Posts 710
marexy replied on Tue, Sep 18 2018 8:06 AM
lift few mm alu profile at the end whre t screws are ... and than slide the oposite way from the screws the alu profile.
that is it...
UffeT
Posts 13
UffeT replied on Wed, Sep 19 2018 11:35 AM
One more question..
Need to know where to buy PCB03 for the BEOLAB 4000?
Is it possible to  obtain one for a resoneble price? Used? Old inventory?
Best Regards
U
Page 1 of 1 (6 items) | RSS
