BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
BeoNut since '75
elephant:I am following the crowd - bought my first Hue and Bridge as an experiment. 💡🌈😊 BeoNut since '75
yes, Hue is, even without Beolink, great. i'll get my motion sensor on thursday. and i don't miss my bunch of lava lamps at all.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Aussie Michael:It's good! You'll love it. Certain places also stock the bayonet version. It seems most places have the edison screw.
I've been using a sensor at my office for a week now. It works pretty well. Setup is very easy with the Hue iOS app. You can set which scene to activate during daytime and select a different scene to activate at nighttime. You can select the length of time of sensing vacancy before the lights are turned off. A nice feature is that it will first dim the lights before turning them off. This gives you a warning if you've been too still at your desk so that you can wave your arm to keep the lights on. This has happened a couple of times. I believe that the sensitive can be adjusted to compensate for this. A find myself appreciating the sensor to turn the lights on hands-free when returning from court with my arms full of briefcases and files.
elephant:You can now order the bayonet through the Apple Store BeoNut since '75
Aussie Michael:Thanks ed. I also see they have the white ambiance. I picked up one of those for the bedroom yesterday.
Chris Hassell:Hey everyone - do we know if the Hue Sensor can be used as an event on the BLGW? BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Hi everyone,
Almost two years ago there was this thread about using the Philips Hue Motion Sensor as a trigger/event for the BLGW.
Any news about it?
If it works, I could integrate it in my KNX-system and have a non-KNX motion detection system. If not, is there another third party motion detection system which works fine with the BLGW? I don't want a KNX-sensor, because of the programming my KNX-system.
Gr. BeoHut
BeoHut: Hi everyone, Almost two years ago there was this thread about using the Philips Hue Motion Sensor as a trigger/event for the BLGW. Any news about it? If it works, I could integrate it in my KNX-system and have a non-KNX motion detection system. If not, is there another third party motion detection system which works fine with the BLGW? I don't want a KNX-sensor, because of the programming my KNX-system. Gr. BeoHut
I use the RadioRa2 occupancy/vacancy sensors as triggers. They work great. In fact, I find them to be more accurate and reliable than the Hue sensor. I use them in the bathrooms to trigger Philips Hue lights on/off in macros. The sensors themselves are inexpensive and very easy to setup. However, you must buy the RadioRa2 bridge.
