If you had the chance, which of the two would you buy? Which produce the better audio? Thank you for your opinion!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Sure - but what if your room is only 20m²....
....would you still put in the BL5’s?
Well the room has more than 100m^2. I have read many posts here that soundwise there is not much of a difference between them. However, I have also read that the Beolab 8000 MK1 and MK2 sound the same, and to my ears there is a massive difference!
Then definitely go for the BL5’s!
Beolab 5, any size room is fine! calibrate them to the room and good to go!
I've got a pair of Beolab 5's, and I've heard a pair of Beolab 20's at a dealership and I can honestly say that the 5's are better by a mile. Hence the purchase of the 5's.
Now that prices are coming down to a reasonable level I decided to buy a pair, you will not be disappointed.
Having heard the 5s in a surround setup (both pairs front and back (bluray movie and bluray audio)) in a 30m^ room and the 20s (playing deezer (FLAC)) in a 70m^ room I can safely say that the 5s are the way to go.
I will agree that it is not fair to compare them head to head but if your dilemma is 5s or 20s go for the 5s.
Just make sure you have the proper gear to connect to them!
Rob.B: Beolab 5, any size room is fine! calibrate them to the room and good to go!
That's not true.
I have them from the beginning,and i must turn down the bass to -3
The bass roomcorrectie can't solve everything
I listened to both side by side; and i preferred the 20s
Aussie Michael: I listened to both side by side; and i preferred the 20s
What did you prefer with the 20's?
