I was hoping to use a Beolink 1612 converter to add an audio signal from my Mac Mini to my Master link system. Which consists of a Beosound 4000, Beolab 2000, Beolab 3500 as well as two passive 1658 amplifiers controlled by independent IR eyes. My only question will this idea really work and will all I need to do is press the AUX control on the Beo4 remote to hear the sound from my computer??? As you can tell I can use some direction on the matter.
Ah, you know... A little B&O here, a little there
Will I some how need to identify the 1612 as a TV? Or use the option settings? Would the 1612 also work as a stand alone MASTER, if I was to not use my Beosound 4000?
striker27:Would the 1612 also work as a stand alone MASTER, if I was to not use my Beosound 4000?
mjmedlo:I think the 1612 is self recognizing. You simply press the button. Unplug everything after you put it on the network.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
