MCP6500 and Beomaster 6500
ronk
Posts 3
ronk Posted: Wed, Oct 10 2018 10:13 PM
Does any MCP 6500 work with any Beomaster 6500 without any changes?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Sure.  As would the hand-held remotes 1000/5000/Beo4.
Soren
Denmark
Posts 115
Soren replied on Thu, Oct 11 2018 5:31 AM
Hi
The short answer is yes, but your Beomaster has to be in option “1” or “2” if it is in option “0” the IR receiver is disabled.
Søren
ronk
Posts 3
ronk replied on Thu, Oct 11 2018 12:44 PM
Thank you both for the quick responses - I should have also asked if there is any special 'pairing' procedure to link the MCP with the Beomaster 6500, and so what are the steps? The reason I ask is that I am trying to get my existing MCP to work with another Beomaster.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Oct 11 2018 12:46 PM
Nothing but the Beomaster option setting as mentioned above.
ronk
Posts 3
ronk replied on Thu, Oct 11 2018 12:55 PM
Thanks Martin, how do I get the beomaster into that Option? I have has my system for over 20 years and did not know these options exist.
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 11 2018 4:41 PM
ronk:
With the system at standby, press SOUND, 1, STORE, or SOUND, 2, STORE.
Basstard
Posts 60
Basstard replied on Thu, Oct 11 2018 5:50 PM
I got 2 of those.
Both of them worked fine directly after i placed batteries in them.
Lots of good advices Thumbs Up
Page 1 of 1 (8 items) | RSS
