Hey All,
I'm Matt and I'm new to the forum. I fix vintage audio for a hobby and was recently brought a 7700 to repair. So far, there have been no major hiccups. Belts, cleaning etc. One problem I am having is that the volume up button doesn't respond. Volume down and mute are fine, it's just up. The only way to get the volume to move up is by hitting volume reset button. I have removed the switch and it ohms out fine. Am I missing something in the programming? It's my first B&O repair so keep that in mind.
Matt
Probably a cracked solder joint at a connector.
I'll check, thanks!
