Hello all!
This may have been answered on another forum, but I could not find the answer.
The new Apple TV 4 has an IR learn feature. Since my projector does not work with CEC, does anyone know if the Apple TV can learn the BeoRemote One for navigation? I use a Playmaker with my BeoLab 5s connected to the Apple TV via AirPlay. I wanted to use the BeoRemote One for Apple TV navigation and for the 5s/Playmaker volume. Has anyone tried this?
Any help would be appreciated! Thanks!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I use My Beoremote one on the new Apple TV...
Beovision 14-55 oak, Beosound Moment, Beolab 18 oak, Beoplay H8, Beoplay form 2i
I thought you could use the BR1 with ATV4, the only thing you couldn't do is the Siri commands
You can control the ATV4 via PUC. I am not sure you can actually learn the ATV4 to use the BR1 directly.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Is it possible to bring down e.g. the subtitlemenu using the Beoremote One on an Apple TV4?
On the ATV4 remote its a "swipe down" maneuver,
Press down.
Is there an updated PUC for the ATV4? ie. I'm looking for the functionality of the HOME button even the double-press of the menu button via a Beo4 ro BeoRemote One. Does anyone know if B&O have added any ATV4 updates to the ATV PUC? If so, is it listed under Apple TV 4 if you search for PUCs?
Sal:Is there an updated PUC for the ATV4? ie. I'm looking for the functionality of the HOME button even the double-press of the menu button via a Beo4 ro BeoRemote One. Does anyone know if B&O have added any ATV4 updates to the ATV PUC? If so, is it listed under Apple TV 4 if you search for PUCs?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael: Sal: Is there an updated PUC for the ATV4? ie. I'm looking for the functionality of the HOME button even the double-press of the menu button via a Beo4 ro BeoRemote One. Does anyone know if B&O have added any ATV4 updates to the ATV PUC? If so, is it listed under Apple TV 4 if you search for PUCs? Yes they have. And even flattened the button pictures for the OSD (now more like current iOS/OS X).
Thanks Michael! I'm going to update the PUC tonight after work! Cheers!
Upgraded the PUC and there's new functionality. Double Press of the Home button brings up the application switcher, but unfortunately I can't find a way to replicate the swipe up to quit an app from the Beo4. For those wondering why I'd want to quit an app. The Youtube app on the ATV4 has been well documented to have picture judder after having played a couple of videos. This is rectified by quitting the Youtube App Process.
Sal:Upgraded the PUC and there's new functionality. Double Press of the Home button brings up the application switcher, but unfortunately I can't find a way to replicate the swipe up to quit an app from the Beo4. For those wondering why I'd want to quit an app. The Youtube app on the ATV4 has been well documented to have picture judder after having played a couple of videos. This is rectified by quitting the Youtube App Process.
Is there a Master Link Version available as well (hence for a Beovision 10)? Or may the PUC code for the ATV3 make it as well?
I have recently had ny beosystem 3 Update with what they Said was the latest puc , but i cant find anyone saing Appletv. Anyone know what precisly it is Called in the menu?
Also i have been trying to get my BeoRemote one to work with beosystem 3 and appletv 4 witout any Luck .
is it me there is an idiot or is it wery complicatet.
pardon my bad spelling
I can tell what your dealer has updatd.
The three available PUC entries for the ATV are shown in the picture below.
Your BROne must be one with ir support. It must be configured for using ir, when one of those with both ir and bt.
Of course you can only control the ATV, if the right PUC is choosen and the ir blaster is attached placed/correct.
Oh - forgot the pic....
Obviasly i payed for nothing. Dont have that appel option.
Finaly Got the Remote Working with Both bs3 and bv7 . Dont know what made it work.
