Beo4 settings for BV7-40 mk2 - Help! :)
Kratmann
Posts 4
Kratmann Posted: Sun, Oct 14 2018 2:53 PM
I am new in this forum, but I hope there is someone out there who can help :)
I just accuired a BV7 mk2 with DVB-HD module.
I have setup AppleTv3 through DVI and sound through the analogue input (using external D/A converter). So far so good...
In my eagor to having the ATV-sound comming through with digital sound I ended resetting the entire system, incl. the Beo4 remote... and now the true problem hit me..... The BV7 is no longer responding to my remote. I cannot figure out how to reconfigure it, so it will controle my BV7.
 Info about my remote (GO+menu):
EE: 6.2
SW:5.00
Video4
Audio2
... no navigation button
I have tried all Video and Audio combination, that I can choose between (OFF+list -> config? -> Video? -> Video1 ... Video4) ... all without any luck.
When I read the manual for the Beo4 from B&O's homepage, there is a nice overview of the equipment the different Video1... Video4 controls, but nowhere is the BV7 mentioned.
Is there someone out there, who can help me solve this mystery?
someone who can post their settings of the Beo4 for controlling their BV7-40 (toggle GO+menu at the same time and browse using List)
I am crossing my fingers
Best regards
Kasper
Millemissen
Flensborg, Denmark
Posts 14,680
Hvilken Beo4 er det?
Med/uden navigationsknap?
Millemissen
Flensborg, Denmark
Posts 14,680
Hvis uden og ‘video-indstillingen’ er problemet, er det Video 1, du skal bruge.
Endvidere skal den ‘knap’ fra LIST, som du bruger (det er sikkert PC), tilføjes.
Tip: flyt den (Move’) langt frem, så du ikke skal trykke så mange gange.
Kratmann
Posts 4
Kratmann replied on Sun, Oct 14 2018 6:11 PM
Mange tak for svar MM.
Det er en Beo4 uden navigationsknap.
Video 1 gør desværre ingen forskel... BV7 vil stadig ikke reagere.
Har også prøvet det øvrige Video 2, Video 3 og Video 4 .... alle uden held.
Men som sagt er BV7 heller ikke nævnt i brugervejledningen for Beo4 (se side 15).
Er det tilfældigt ? Er der et specielt trick til BV7, som ikke er beskrevet i manualerne?
Mvh
Kasper
Fritz
Posts 272
Fritz replied on Sun, Oct 14 2018 7:37 PM
Hej
Fjern batterierne i Beo 4
1. Vent en time. derefter sæt nye batterier i (Brug evt en batteri tester, su du er sikker.
2. Brug en anden Beo 4 eller Beolink 1000, så ved om det er fjernsynet eller Beo 4.
3: Test Beo 4 på et andet TV.
mvh/Fritz
Millemissen
Flensborg, Denmark
Posts 14,680
Hvis ikke Fritz’s råd virker, så find ud af om du - ved et tilfælde - er kommet til at sætte dit tv i Option 0,
hvilket betyder, at det slet ikke reagerer på en fjernbetjening.
Kratmann
Posts 4
Kratmann replied on Sun, Oct 14 2018 11:35 PM
Hej Fritz og MM
Det virker igen!! :)
Det var sat i option 0. Da jeg ændrede det til Option 1, virkede det igen :)
Tak for jeres input.
Mvh
Kasper
Page 1 of 1 (7 items) | RSS
