Hi everyone,
I am restoring right now Beomaster 4400, I recap all electrolytes, and the beast came alive, no signal current are set - sounds beautiful! Phono 1 and 2 works perfectly, FM also tune nicly with stereo. I found out one problem with AFC and I am stuck. In FM mode when I swith on AFC function it mute both chanels, even with strong stereo signal. I can tune the signal but ther is a shift in comparison to (AFC OF) and the volume is decreased around 8 times when AFC is ON.I have checked conections on AFC button (77 and 80) seems to be ok,and also tranzistors TR7, TR8 and TR9 they are all good.Any idea... suspections, experiences.. ? wich might be helpfull.Regards,maciej
The AFC function is strongly related to the muting circuit.The button is labelled AFC-ST, where ST stands for Silent Tuning (muted between strong stations).Most of the problems in these areas are caused by wrong wattage tuning discriminator lamps.
Thank you Martin, I will try to play a bit with this area.maciej
Hi Martin, you were right, I have changed the bulbs and it works perfectly.Thank you,maciej
