BeoNut since '75
elephant:Software is ... a weird and wonderful thing
Sounds like someone needs to be doing some "sneak circuit" analysis of the s/w.
Jeff
mbolo01:Btw: the M3 refuses to start if power off and on are too close, I have to wait several minutes to plug it back on the mains, anyone has observed this ?
Yes, same with the BS35
No idea for the M3s because I never needed to do that, they work like a charm (even double press to join the BS35 is perfect)
mbolo01: Ticket opened with Beocare since one week, no answer yet or no care
Software update will fix it. Then nothing will work, but hey, it's at least consistent then.
mbolo01:Press the upper M3 button to join the Moment
CB:Do you « double press » this button to join in synchro?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
If M3 is off and everything else also = all standby, one press will activate the first source in the local list ( usualla netradio/TuneIn - on last played station).
Jeff: elephant:Software is ... a weird and wonderful thing Sounds like someone needs to be doing some "sneak circuit" analysis of the s/w.
Here is another one....that Jeff can add to his list of need ‘sneak circuit’ analysis.
My BV obvisiously runs on battery ;-)
:) looks amazing, avant on battery
