RJ45 PUC pinout
3400SJ
Posts 25
Silver Member
3400SJ Posted: Sun, Dec 30 2018 5:45 PM
Does anyone know the pinout of the RJ45 PUC connector I would like to re-terminate a couple of the older type, I will buy some new ones in the new year but this would be useful for now
Stuart
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Dec 30 2018 7:29 PM
Try page 88 of the BV11 service manual here: https://www.beoworld.org/manuals_view.asp?pid=1292
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Stuart,
I have the 3.5mm to RJ45 PUC adapters available here if you need them: https://soundsheavenly.com/televisions/178-2548-35mm-to-rj45-ir-puc-adapter-for-beoplay-v1-beovision-1112avanteclipse.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
3400SJ
Posts 25
Silver Member
3400SJ replied on Mon, Dec 31 2018 10:59 PM
I found the details in the service manual, I will buy an adapter shortly but I wanted to get it going tomorrow
Stuart
Page 1 of 1 (5 items) | RSS
