Transportation of BV 7-55
MartinRK
Posts 80
MartinRK Posted: Wed, Oct 31 2018 9:02 PM
I have just bought a BV 7 55 MK II from 2013 Smile
I probably have to transport it in the trunk of my car. Is it okay to transport it lying down or should it stand up?
If lying down, should it be on the backside or the front side (screen down)?
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 31 2018 9:42 PM
The preferred method is standing up, but personally I'd be happy transporting an LCD TV flat if carefully supported and padded.  Watch out for potholes!
Millemissen
Flensborg, Denmark
Posts 14,680
MartinRK:
I’d have it on the backside - and beware of the blu ray player-part, that it won’t get damaged
The Beonic Man
Bristol
Posts 812
It's fine if you're careful; it's only plasma screens that need to be upright when transported.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
MartinRK
Posts 80
Thanks for the advises
I will give it a go, and put it on the backside, carefully supported by all kind of soft materials...
beolion
Posts 485
beolion replied on Thu, Nov 1 2018 11:10 AM
Yes. I did the same and it worked fine.
Just be careful with the built in bluray player tray.
MartinRK
Posts 80
MartinRK replied on Thu, Nov 1 2018 11:13 AM
I will for sure
Page 1 of 1 (7 items) | RSS
