Hi all,
can anyone recommend any external cameras that will work with the BLGW and record onto a QNap server in the UK?
thanks
Toby
Regards
Kiran
Born in NL; I ride ML
Kiran is correct in his answer.
The BLGW supports now, with the latest firmware, H.264 compression.
Almost every IP-camera can be connected to the BLGW. Have a look at this site: https://www.ispyconnect.com/sources.aspx
Suc6!
Thanks Kiran and Beohut, didn't realise the latest release supported H.264 so should make it a lot easier to chose. Will look through the ispy link and see what looks good.
Any brands in the UK that are recommendedover others for external, internal and NVR? Thanks
