Hi all, I've been trying to connect my BC2500 up to my A6 but I'm having problems with the AUX auto sense on the A6 kicking in every minute or so and switching the input being used to AUX rather than whatever is already playing. I'm using the left PowerLink output on the 2500 with a PL -> 3.5mm cable.
I'm assuming the 2500 is sending some kind of signal out because it thinks PowerLInk speakers are attached, so I'm wondering is there a way to either stop that or disable autosense on the A6's AUX input? Don't mind manually selecting AUX manually in the B&O app/with the Essence remote/on the A6 itself if needed.
Cheers.
Did you try to use the Aux-port of rhe 2500 instead?
Long ago....I am not quite sure that it has sound out, but I’d suppose so.
I always assumed that was input only, but I'll give it a shot just in case!
leosgonewild:Does it happen if the BC2500 is turned of?
Yep - that's the problem :(
