Does anyone have an arm for the Beogram 4000 or even just the connecting part for the cartridge? Even an arm for a Beogram 4002 will do as it can be made to fit.
Is your tonearm broken or is it just the cartridge connector that is broken (very common with the Beogram 4000). If it is just the cartridge connector then why waste ruining another good arm when you can just buy a new tonearm cartridge connector from Beolover's parts?
-sonavor
I'm looking into doing just that. Do you know whether the plastic is as robust as the original?
I have used the Beolover part on two of my Beogram 4000 units and it is very sturdy. I don't know if B&O changed their material in that piece later because it seems to be an issue with the Beogram 4000 and not the turntables that came after it.
