BS9000 Cleaning Required after cleaning
This post has 3 Replies | 0 Followers
plumber77
Posts 76
plumber77 Posted: Thu, Nov 29 2018 7:45 PM
Hi
I've read all over this and done my best with the unit.
Removed glass door and cleaned, both finger pins, behind the sledge all inside the machine where I can get and the laser with a cotton bud.
Still comes up with cleaning required, Is there anything else I've missed??
I've deactivated safety mode and the 'cleaning required' has disappeared. TM74
I presume it bypasses this with the safety mode off??
Is there a major issue with leaving it off apart from loosing fingers!!
Unit now works a dream.
Could there be simply a fault on the finger protection circuit.
Thanks in advance
Mark
Beosince98
Posts 274
Have you cleaned the small prisms?
plumber77
Posts 76
plumber77 replied on Thu, Nov 29 2018 8:07 PM
Hi
Cheers for the reply.
Yes that was the first thing I did.
Regards
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Fri, Nov 30 2018 10:26 AM
I was fooled by one of these!!! You need to clean the transmitter and receiver "prism's" all around,not just the flat parts,and use spec's cleaner ideally,as any film left behind by other cleaner's will affect the operation too.
In a worst case of course,you may have a fault in the safety circuit,but this is rare.
Nick
Page 1 of 1 (4 items) | RSS
