iPhone shurtcuts für blgw
moritz001
Posts 17
moritz001 Posted: Wed, Nov 13 2019 1:50 PM
Hello
I suppose I'm not the only one who wants to control the B&O system with Siri or similar. On one side is the blgw, which receives the command and then executes a macro, on the other side is the iPhone, which sends the command.
Now my question to the specialists in the group: is that possible?
There's a great app for iPhone that lets you program shortcuts: (https://apps.apple.com/ch/app/kurzbefehle/id915249334.) Couldn't you make an http string that could be called later with Siri and execute a macro on the gateway?
What should a Custom String (get / post) look like, how can you send it on the iPhone with shortcuts and what exactly would you have to set on the gateway?
I am looking forward to your ideas and suggestions and would like to thank you in advance.
Moritz
Page 1 of 1 (1 items) | RSS
