i have been troubleshooting my BeoMaster 6000.
The unit won’t turn on. The power supplies are all good, the micro controller on board 2 is not starting as I can see defined input pins not pulled up to 5 V which should occur as soon as the micro controller starts. The crystal, reset, power, ground etc are all good. There is no key scanning going on, another indicator that it is not running.
i would appreciate anyone with suggestions on where I could obtain a Board 2 from. eBay NA does not have any listed.
Thank you in advance for your replies.
Dennis
