Beogram 1202 belt?
This post has 3 Replies | 0 Followers
Ninni
Solna, Sweden
Posts 22
Ninni Posted: Thu, Dec 6 2018 2:08 PM
Hi all. I used to be a member but haven't been active for several years. My old login didn't work, so I re-registered now.
Anyway, I'm wondering if drive belts for the Beogram 1202 etc. are available nowadays.
I have a Beogram 2000, which seems to be identical to the 1202, except for the lid.
It still works but spins up very slowly when you start it. After a couple of seconds it reaches the correct speed though.
I'm thinking it would be wise to aquire a spare belt if they are available now.
Ninni
Solna, Sweden
Posts 22
Ninni replied on Thu, Dec 6 2018 5:08 PM
Thanks Martin. I'll try to order a belt then.
Ninni
Solna, Sweden
Posts 22
Ninni replied on Sun, Dec 23 2018 5:22 PM
I installed the new belt and it made a big difference. Now the Beogram reaches the correct speed very quickly. Thanks again Martin.
Page 1 of 1 (4 items) | RSS
