CCA and BV5/7
steve1977
Posts 911
steve1977 Posted: Fri, Jan 4 2019 5:20 PM
I’d like to connect a chromecast audio to my BV5 (hd ready) and BV7-55 (3D). I remember from forum conversations that this may not be as easy as it seems. How can i set this up and possible to use the remote to select the audio-only channel directly. i’m using a One, so am somewhat limited in terms of programming the remote. Thanks!
Page 1 of 1 (1 items) | RSS
