OlivierC:In other words, is there any chance to voice control a BV11, BV7 or a V1?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I would say its because the interface in the mentioned Beovisions is not built for voice command.
HDMI-CEC has nothing to do with voice commands, or do I misunderstand you?
What in the TVs do you want to command with voice?
If you connect an Apple TV you can do quite a lot with voice command, but then its the AppleTV you work with.
