beo4 mk3 gone directional
ebnrob
UK
Posts 174
ebnrob Posted: Thu, Jan 3 2019 5:09 PM
Hi all,
One of my beo4 (mk3 DTV) remotes has developed a problem whereby it only works when pointed directly at the device. I changed the batteries for fresh ones to no avail, swapped them with batteries from a working beo4, no difference, then last night checked to see that the IRs were firing using my phones camera and saw only one of the 2 IR emitters is lighting up! Could some special low power mode been activated through accidental key press? As far as I know it's not been dropped but can't rule that out with 2 kids in the house. Is there a way to reset the mk3 remotes? There isn't an option in the settings menu in this one to reset.
Thanks for your help.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 3 2019 8:07 PM
I found this about setting the IR strength:
https://archivedforum2.beoworld.org/forums/p/7442/66207.aspx
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Jan 3 2019 8:23 PM
beojeff:
I was looking for that explanation too, but couldn't find the details - sadly it's only for the Beo4 with the joystick.
Having fixed/reconditioned many remotes, I've never experienced a single IR transmitter failure. IIRC the IR transmitters are attached to the main PCB, hence I would suspect a breakage or failure at the contact/solder point.
ebnrob
UK
Posts 174
ebnrob replied on Fri, Jan 4 2019 8:24 AM
Thanks for the help Guy. After receiving your post last night I decided to take the remote apart and the IR connections appeared to be OK. One thing I noticed was the IR that did work didn't appear as bright through my phone's camera compared to my other mk3 remote. I decided to put it back together, tested it and to my surprise the remotes working again!! Both IRs light up and are bright! Very strange. Rob.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 4 2019 9:28 AM
Great news.  I must admit that last time I 'fixed' a Beo4 I simply took it apart and put it back together again!  Perhaps those small rubbery strips that provide contact to the screen play a greater role in the internal electronics Smile
Page 1 of 1 (5 items) | RSS
