Beoworld members have ordered restored panels for Beolab 5000 and Beomaster 5000 from me - Classic Audio over the time.
I have discovered a problem on some items of the latest shipment from the factory which I have not seen before.
The issue is "smeared" text.
I you have panels where you think the text have this problem, you can very easily remove the problem.
You can clean your panels with isopropyl alcohol.
Your panels can be cleaned with isopropyl alcohol because the new restored panels the text is anodised.
Frede Kristensen - Classic Audio
OBS.
This cleaning is only recommended for the new restored Beolab 5000 - Beomaster 5000 delivered from Classic Audio.
The original panels - DO NOT - try to clean with isopropyl alcohol !!!
