I am repairing one of these with a CD fault. It uses the CDM12 laser. The fault was that the CD would not even spin up, I have replaced the laser with one that has the chip, not the copies, I've also replaced the two capacitors on the board 330uF and 100uF. I found the flexible cable to the motor broken so I carefully repaired that.
Now the CD does spin, but not fast enough and after a few seconds it stops.
Can anyone help me?
