Beolab 4 powerlink cable
Soren
Denmark
Posts 115
Soren Posted: Thu, Jan 24 2019 11:33 AM
I am thinking of buying a pair of Beolab 4, I have and old 20meter MK1 powerlink cable... will that work or do I need to buy some MK3 cables?
Søren
BenSA
Durban, South Africa
Posts 1,404
BenSA replied on Thu, Jan 24 2019 11:45 AM
Hi
According to the manual it has to be the powerlink cable with a triangle on it.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Soren,
You need mk.3 Powerlink cables to prevent background noise on newer speakers like Beolab 4:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
