Hello forum
I have a Bosscom remote cable, that I thought I could use a puc cable - but i does not work. What cable do work? From the RJ45 to the DVB box?
Maybe try one from Steve: https://soundsheavenly.com/televisions/60-2545-ir-transmitter-blaster-for-beosystem-4-beoplay-v1-and-beovision-11avant-rj45-control-socket.html#/2-length-1m
It looks like the right one. Do you know if he shippes to denmark?
Master123456789: It looks like the right one. Do you know if he shippes to denmark?
He ships free - anywhere in the world!
Another recommendation for Steve here. I've actually found his IR Blaster cables to be better than the originals.
Lee
Thanks guys!
Yes, the cable mentioned in the thread above is the correct one and this includes free shipping to Denmark by Airmail.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks - and how much for 2 or 3 meters? :)
You'll need to order from the website. It says it's a 1m Cable on the drop-down option, then says in the description it's a 3m lead as standard.
I am almost certain it's a 3m cable, but maybe Steve can confirm?
Here is the link to the page you need.
CLICK HERE
The link only shows 1 meter and the drop down only shows 1 meter ;)
I will have 3m cables coming into stock in the next few days. Please feel free to get in touch via my sponsor link below and I can answer any questions that you have.
I am pleased to confirm that I now have the 3m cables back in stock at the link below:-
https://soundsheavenly.com/televisions/60-2545-ir-transmitter-blaster-for-beosystem-4-beoplay-v1-and-beovision-11avant-rj45-control-socket.html#/2-length-3m
