Hi all,
my beosound 9000 was broken. No standby light, nothing.
I found out that the pcb 43 powersupply was defective.
so I replaced it with a used one.
after that standby light comes back. I did the testmodes for cd drive, everthing ok.
now my Problem is.
I can use the cd without any Problem. I can choose A.Aux no probs.
But Icannot choose the Radio. If I try the 9000 shut down and comes back to the standby Modus about 2-3 seconds later.
I don´t think it is the Radio platine, because I tried two different of them.
Testmode 27 Shows IIC error 98
I can not use specific testmodes for Radio. Same Procedere, 9000 shut down
maybe someone of you has some ideas for me.
Thank you Markus
