setup as follows:
room1. BC2300 (A.opt 1) + Converter 1611 connected via Masterlink to the Beolink Wireless transmitter
room2. LCS9000 (ML enabled, L.opt 6) connected via ML to Beolink wireless receiver
According to the official Bang&Olufsen support this should not work but in fact it does. Just one issue: when the LCS9000 is switched off the BC2300 doesn't go to standby, it has to be switched of manually.
question: would the change of the microprocessor (to SW 3.?) in the LCS9000 help in this situation?
