Beogramm 3300 scraping noise
astjerne
Posts 3
astjerne Posted: Mon, Feb 4 2019 4:32 PM
My Beogram 3300 of 30 years seems to run a little unbalanced, thus making the metal 'platter' or plate scrape against something somewhere on the inside making an annoying scarping noise when playing a record.
I've tried to take it apart more that once, and sometimes I succeed in getting it to run straight/without noise for short period.
Any good ideas? The turtable has never been serviced, so all part are as they were when I bought it.
/Christian
Steffen
Denmark
Posts 1,408
Steffen replied on Tue, Feb 5 2019 10:38 AM
It is quite common that these turntables start making a scraping sound, as they grow older. Often it is quite easy to fix -a matter of adjusting the level of the subchassis.
The 3300 is actually (apart from the looks) the same as the BG 3000, 3500, 5005, 5500, 6500, 9000, 9500 etc.
-maybe these old threads can solve your problem:
https://archivedforum2.beoworld.org/forums/p/20987/172640.aspx#172640
https://archivedforum2.beoworld.org/forums/p/870/7060.aspx#7060
astjerne
Posts 3
Super!
Not extremely easy to finetune it, but obviously the solution to the problem.
thanks!
Page 1 of 1 (3 items) | RSS
