Beovox M75 and other cabinet restoration
This post has 7 Replies | 2 Followers
Chris
Nottingham UK
Posts 31
I acquired these speakers and unfortunately they have some damage to their corners. Has anyone attempted such a repair and how badly does it diminish the value of the speakers. (all other things in good shape aside from a couple of corners that is).
Chris
Nottingham UK
Posts 31
Chris
Nottingham UK
Posts 31
Chris replied on Tue, Jan 29 2019 3:09 PM
Some additional images.
Chris
Nottingham UK
Posts 31
marco
Turin
Posts 65
marco replied on Tue, Jan 29 2019 10:14 PM
Hello
honestly I'd be more worried about crumbled foams of woofers and midrange drivers, wooden defects are last issues to solve
Marco
DMacri
United States
Posts 881
DMacri replied on Wed, Jan 30 2019 10:15 PM
Refoam the woofers and midranges and correct the fading finish. That will have the greatest impact in value. The corner is a minor cosmetic issue.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Thu, Jan 31 2019 1:31 AM
It’s been awhile, but I fixed the corner of a P45 or P30 cabinet. You have to pull the Aluminum out, straighten it, then reinsert. Of course you also have to repair the corner with some glue.
As already stated, though, that’s the least of your concerns.
Chris
Nottingham UK
Posts 31
Chris replied on Thu, Feb 14 2019 11:55 AM
Hi All,
Of course the woofer and mid range are going to be restored. :) That's why I bought them, I have started adding teak oil to one speaker here with some light sanding with foam pads.
It is reassuring that you think there might be some value left in these speakers. I was very saddened to see the damaged corners :(
I also have the stands (black height adjustable) which need a light sand and coat in smooth hammerite paint.
The covers  I am also going to recover with fresh cloth as they are tatty and mouldy. Half tempted to go for dark grey instead of black, in the hope that the colour takes away from the damaged corners.
Page 1 of 1 (8 items) | RSS
