Gentlemen
I am in question of the Beomaster 5000 remote and system working with the Beocord 5500. I noted on a photo (ebay) that the 5500 has auto reverse. The 5000 Beocord does not. Will most functions still work with the remote? OR should I just stay with the same system 5000 all around for compatibility .
As always you all are the best.
Stephen
Thank you ...now the hunt begins for a unit to purchase.
My best Stephen
