Is it error on autostart part of PCB or ST-By part ?
So ..any suggestions :) ?
I discovered no mistake yesterday...so dead end :(
taoday after hour of work..no positive news
so the situation...
If i switch to PWL ..position to L or R seting and than pug in mais 230v than spekar work normal.
Relay switch on ...
It power's on from st-by normaly... and go to green..play normal after activation of Beocenter as it should. and go to ST-BY if i turn of Beocenter.
if during proces of playing i turn switch to LINE, and than back to PWL ... indication led on speaker go to orange and not RED as it should.
And diffrent story on LINE seting
If switch is on LINE -RCA and if i plug in mains 230v than on spekars for few sec. produce high frequency sound and than play normal.
Than... if i unpalag RCA cable or stop playing music , speker not going to ST-BY.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
