Hello all,
I have a pair of Beolab 8000's that I use with an Onkyo NR-709. The problem I have is that the speakers keep being on (green) even after the receiver has been turned off. To me it seems like the receiver keeps giving the speakers some kind of signal? However my sub, which also is from the pre-outs, turns off as is should a bit after the receiver is turned off.
I previously had a Yamaha receiver, and did not have this problem at that time, however the speakers have not been used for quite some time, so I'd like to rule out the speakers before I start looking for a new receiver.
Does it "hurt" the speakers that I pull the plug out when I'm done watching Tv for the evening?
Try disconnecting the line in cable and check if they still remain on. If they do, then the problem is in the speakers. If they don't, then the problem comes from your receiver (probably a ground loop or humm noise).
When I leave the speakers powered-on but unconnected they are mainly green but turns red like every two seconds.
Hi db8000,
Some Onkyo receivers make a physical disconnection to the pre-out sockets when they are powered off, which can leave Beolab speakers with an "unbalanced line" condition that allows the speakers to pick up induced electrical noise, hence turning them on unexpectedly.
The same situation can occur if the speakers have cables connected, but no receiver plugged in. You can reduce this issue with good, well shielded cables and by moving the speaker cables away from any mains power cables. Turning off other electrical items in the room can also resolve the issue if they are causing the electrical noise that the speakers are picking up - you can test this by turning off other devices one at a time to see how this affects the speakers.
A good test of the cabling would be to plug a phone (or similar device with a headphone socket) into the receiver end of the cables via a 3.5mm to RCA adapter, then see if the speakers function well without noise. If the noise is absent then the issue is with the receiver.
Please let us know how you get on so that we can assist further.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thank you for your answer! It's a shame I didn't know this before I bought the Onkyo. I think my cables are of pretty good quality, but its a snakes nest behind my TV I think I'll try getting a new (to me) receiver instead as I am not happy with the lip sync on the Onkyo anyways. I've been looking at a Marantz SR6007, do you know if that has any similar issues?
Thanks in advance
I haven't heard of any issues with the SR6007 - maybe other Beoworlders could comment if they are using this receiver with Beolab speakers?
It is also worth tidying the wiring and checking that the speaker cables and mains cables are run separately, as this will help to reduce any noise or humming problems.
Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Hello again!
I found a used Yamaha RX-V781 that I'm thinking of getting, just thought I'd hear here before if anyone has used one and if so, if they've had any problems with it?
I'll reply to myself. I went ahead and bought that Yamaha receiver, and it doesn't keep the speakers on when they're supposed to be off.
Thanks for the update, glad to hear that all is working well.
