Hey Guys!
I have a problem with my Beosound 1s IR receiver (I think).
If I operate the Beo4 very close and in a certain angle to the BS1 (aprox. 10-15cm away) it works fine. If the Beo4 is any further away, it does not work.
I have tried a different Beo4, new batteries etc. so I am pretty sure the BS1 is the problem. See also this thread: https://archivedforum2.beoworld.org/forums/t/36179.aspx?PageIndex=2
The BS1 otherwise works perfectly fine. I changed SMPS power supply a few weeks ago.
I do not see any IR lights on the BS1 through my phone camera.
Does anybody have an idea how to fix this? Preferably without changing the Display/IR PCB for a new one?
Thank you in advance !
Carlo
Can somebody help?
Regards
beoboehm: I do not see any IR lights on the BS1 through my phone camera.
I have no real advise other than that you will not see any IR lights on your camera since the BS1 does not transmit anything. The BS1 only receives.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I had the same problem with one of mine. The power supply section was bad, which I changed first. The unit then worked, but the remote would only work right up next to the unit. I ended up replacing the Display/IR pcb and that solved the problem.
Good luck with yours
