beocenter 7700 No sound??
Dogfrog0
Posts 6
Dogfrog0 Posted: Wed, Feb 27 2019 10:55 PM
HIi I have a beautiful beocenter 7700 that is partly working..! I no longer get any sound via the phono or cassette (no areal to check the radio) but I get great sound through the AUX cable to my phone??  What could be the issue?  Many thanks rich
solderon29
U.K.West Midlands
Posts 764
How are you connecting the 'phone to the unit?
It's a common misunderstanding that the 5 pin Din connection at the rear of the unit is an auxiliary input.
It is in a way,but it was intended as an in/out port for the connection of a external device such as a graphic equaliser,and when not used for that,there is(or should be) a link plug fitted into the socket.
If there is no link plug or external device to complete the loop,you get the problem that you have.
'Phones,Bluetooth receivers etc  can be connected to the TP2 port.
Nick
Dogfrog0
Posts 6
Dogfrog0 replied on Thu, Feb 28 2019 9:56 AM
Hi nick, it is a direct Din cable operated via the TP2
Dogfrog0
Posts 6
Dogfrog0
Posts 6
solderon29
U.K.West Midlands
Posts 764
"direct Din connection to TP2"?
Is the greeny/grey dummy plug in place in the round multipin Din socket at the rear of the unit?
Nick
Dogfrog0
Posts 6
Dogfrog0 replied on Thu, Feb 28 2019 5:15 PM
I took that out and plugged my cable in
solderon29
U.K.West Midlands
Posts 764
That's the problem,as I mentioned earlier.You need to put the link back in to restore normal function of radio,phono and tape 1,and connect your phone to Tp2("play") via RCA connector's.
Nick
Dogfrog0
Posts 6
Dogfrog0 replied on Thu, Feb 28 2019 5:49 PM
Brilliant it all works again,  thank you so much nick, I’ll look out for the correct cable. Thank you again for your help.
Page 1 of 1 (9 items) | RSS
