Hi I have a set of beovox s60's speakers .
And I'm also running 2 says of penta 3' all run by beosystem 7000..
No my problem is with the s60's
When I turn system volume high the amp turns the volume low I'm taking it's to protect the speakers..
So my question is
1. Have the s60's got a problem., if so can they be fixed
2. What other bookshelf speakers would you recommend for high volume.
Thanks colin
