Hi has anybody done this? I have two lab 8000s as fronts and ideally I want 6000s as rears but due to space issues I can't do this at the moment. Wall mounting isn't an option either as they will get bumped into to much. My only option is wall mounted high up so I had started thinking about 4000s but then I thought about using a lab3500 as I have two only one of which I'm using. Also I think the lab3500 would look better. Would there be a delay with lab 3500s using masterlink?
Thanks all in advance
