Hello, I own Beomaster 2000 type 2913 and Beocord 2000 type 2923 and I want to buy speakers for that setup. Which one should I buy? I'm thinking about ones from Red line series, but which ones would be the best? What about RL 140? Looking forward for your recommendations!
Thanks for your opinion! And what do you think about S45.2?
jedrek:Thanks for your opinion! And what do you think about S45.2?
Hi jedrek,
Welcome to Beoworld!
I would also recommend RL60, RL60.2 or RL6000 speakers, they are superb and well suited to an amplifier like the Beomaster 2000.
Also an option are the newer powered Beolab speakers, which can either link directly to the Beomaster headphone socket, or they can connect to the speaker terminals of the Beomaster via a small converter: https://soundsheavenly.com/line-in-connection/33-power-amplifier-to-beolab-line-in-attenuated-convertor-kit.html
Any questions, please ask!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
