Hello beoworlders
I am planing to purchase a pair of beolab 3, a beolab 7.2 and a beolab 11 subwoofer as my front speakers. And I am think connect them to a Loewe's system. As you might properly known, Loewe has a convertor plug for beolab speakers though Loewe's audiolink socket, and this convertor plug has sockets for center, front, back and subwoofer. I assume I can just connect beolab speakers to those socket accordingly.
However, my question is I am not sure how to let beolab 11's low pass filter work for beolab 3s in the set up. The build in low pass filter is the key point to purchase a b&o sub. Would below methods work?
convertor plug's subwoofer socket => beolab 11 sub in => powerlink out to beolab 3s, and
convertor plug's center speaker socket => beolab 7.2
Or Loewe system has build in low pass filter, just plug everything is right socket,then the system can solve things automatically just like a Beovion?
Btw, I am going to use the Loewe MediaVision 3D, it has build in Dolby and DTS surround sound.
Hope you can understand what I mean.
Best wishes
