Essence 2nd gen - new sw 1.20?
This post has 16 Replies | 1 Follower
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen Posted: Mon, Apr 1 2019 5:00 PM
I just noticed that there is a new sw for the Essence (2) called 1.20xxxx.
My Essence runs on 1.19xxxxx - it is set to manually update.
What is in it - anyone?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Don't know either.
I use Beotool regularly to discover that there is or are updates for one or more devices. Not every update is announced.
At least I have only have green dots now at the products status.
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Apr 1 2019 9:22 PM
Both my Essence v2 and BS2 v1 updated to 1.20.xxx early this morning (Apr-1).  I cannot find any release notes nor any new functionality.
I also noticed that B&O has dropped the "support" area from their website (where you could sometimes find this information).  With respect some recent posts on this forum, I guess it's better to take the support area down, than to leave it up and give people false hope. Whistle
Millemissen
Flensborg, Denmark
Posts 14,680
You can still access these informations here:
https://www.bang-olufsen.com/da/product-support/sound-systems/beosound-essence-2nd-generation
But alas, they did not update ihat page for a long time now.
Razlaw
Posts 4,345
Razlaw replied on Tue, Apr 2 2019 1:19 AM
My M5 was also updated and am manually updating my Essence now.
Aussie Michael
Melbourne, AU
Posts 3,730
Stan:
1990
Posts 521
1990 replied on Tue, Apr 2 2019 8:47 AM
Well, I woke up today with my integrated Essence and M3 playing from an alarm timer. They played perfectly in sync for the first time!
Hopefully we can get hold of release notes, I'll ask support.
laseralex
Posts 240
laseralex replied on Wed, Apr 3 2019 12:01 AM
"I woke up today with my integrated Essence and M3 playing from an alarm timer"
Are you able to elaborate on how you set this up?
I'd love for my M5 in the master bath to start up in sync with the Essence in my bedroom in the mornings.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Sweden
Posts 357
Silver Member
Martin replied on Wed, Apr 3 2019 9:34 AM
I have two A6s. One of them updated yesterday to 1.20 software. The other will not update to new software for some reason. It still has 1.19 and says that software is up to date. If I use BeoTool it says there is new software for the A6. I have tried to reset to factory but it did not help. After factory reset I can not login to Deezer or tunein either. Does someone know What is wrong with my A6?
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Beobuddy
Posts 3,972
Millemissen:
I noticed that there is an option under product setup called problem solving, where you restart and back to factory default.
I don't know whether that was there before (I asked that for that option as my M5 sometimes doesn't respond to the Essence remote and restarting the M5 seems the only working option, instead of taking the powercord off)
mbee
Paris, France
Posts 1,842
mbee replied on Wed, Apr 3 2019 9:05 PM
@Martin : I had the same behavior, it seems that Beosetup can see every update available but that the products can only see the updates when they are really available for them (almost all companies use delay updates to ensure that if there is a problem, not all customers are touched : for example update 1% of users day one, 10% day 2, 30% day 3... )
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Apr 3 2019 10:43 PM
mbee:
Correct. My M5 was first updated, then my A6 and finally the BS 1 this evening, despite BeoTool claiming an update was available much sooner.
Sweden
Posts 357
Silver Member
Martin replied on Thu, Apr 4 2019 9:07 AM
Mine A6 updated yesterday after a telephone-call to support. Now all "dots" in the Beotool-app is greenBig Smile
Millemissen
Flensborg, Denmark
Posts 14,680
...and what has changed fom 19 to 20?
Aussie Michael
Melbourne, AU
Posts 3,730
Millemissen:
As B&O dont really write what’s updated, my guess is that its now support for the BeoRemote 1 now that it is no longer BETA.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Apr 11 2019 6:30 AM
Core and M3 have been updated too, no obvious changes or improvement I could find and perilous products’ issues are still present.
Beobuddy
Posts 3,972
Beobuddy replied on Thu, Apr 11 2019 7:18 AM
I don’t know whether it is new or I haven’t noticed before, but I can now reboot the M5 from a distance after it has lost bluetooth connection with the Essence-Remote. After rebooting the M5 the bt-connection works again.
Page 1 of 1 (17 items) | RSS
