I have B&O system composed by an AV9000 , 2 Beolab 8000 (front), 2 Beolab 6000 (rear), and BeoCentre 2500 with Beolink converter. All are functioned well.
I want to change the tv to a 65" non-B&O Smart TV but keep using the existing sound system.
I have consult the local B&O dealer, the technician is helpful and advise me to purchase an suround amp with pre/pro-out, RCA out-put, system 3 tunner and DC12V trigger on/off. But actually, I cannot fully understand and he cannot advise the band and model on his postion.
My question is that:
1. Is it really impossible to keep the centre speaker of the AV9000 if I remove the TV body?
2. What non-B&O amp can suggested?
3. Any B&O product can serve?
DUPLICATE POST - USE OTHER THREAD
BeoNut since '75
